Several companies made 5x4.5 and 5x4.75. I don't see it being possible to have a 5x4.5 and 5x5.5 on the same wheel. The center hole on most 5.5" patter wheels are 4". That would leave around .25" on the inside of the stud before cone recess.
I saw a set of those once. I fit 4.5 on 5 and 5 on 5 bolt patterns. The rim instead of having your standard hole had an oval tapered hole. Then you had special oval tapered washers with a hole drilled off center. Flip the washer one way it fit 4.5 on 5, the other way it fit 5 on 5. Then your reular nuts fit down over the whole thing. THe set I saw was well used and the tapered oval holes on the rim showed signs of the washer moving inside the hole. Wouldn't recommend it.
