boise49ers said:
Because the way the front lower bushing lines up with the Axle mount. With fixed arm they will only drop as far as the mount will allow because the way the bolt runs Horisontal thru the it. With the adjustables they twist and allow it droop more with out binding. If you look closely at the picture of the RED XJ that is on the thread earlier it kind of gives you an idea what I'm talking about. You catuallu have to notch part of where the Trac bar mount on the Passenger side because it catchs on the metal surrounding the mount bracket. I could get some pics probably and show you what I mean for both the adjustables and the trac bar.
I think whats happening here, is you don't actually know what you are talking about.
EDIT: (that wasn't meant to be offensive in the way it probably came out) :EDIT:
You are talking about ARTICULATING control arms, and not ADJUSTABLE control arms. A "adjustable" arm states only that you can adjust the length - and any -quality- adjustable arm will not articulate for the reasons I stated in a prior post on this thread.
For any given arm manufacturer, if you put ther adjustable vs fixed arm on the same rig, they will both flex and droop exactly the same.
Your Tera arms are adjustble yes, but thats really incidental. Your arms have thick acme threads that are designed to let the arm twist, because of the cheap rubber bushings used at both ends of the arm. Eventually those threads will wear out and leave you with sloppy control arms - or the threads will just tear out of the arm entirely. A quality adjustable arm will have a jam nut to stop it from articulating, and then have a flex joint at one or both ends to allow suspension flex. The joints are usually welded on offset to the tube to get more droop without hitting the frame mount as well (something else you brought up), but that is also 100% irrelivent to 'adjustable'.
Look here, the arm is upside down in the picture, but you can see the rubber bushing at the frame end, the flex bushing at the axle end, the offset tube to clear the mounts at the axle end and the jam nut to stop the threads from articulating. This is a rubicon express superflex adjustable.
Here is the same arm in fixed. Notice everything is the same, except you cant adjust the length.
If you feel thats not going to be enough articulation for you, Currie offers adjustable arms (with jam nut) that have flex joints on both ends - but you give up a little comfort removing the rubber bushing.
