comanche91
- Sweet Home Alabama
I use the same host and have no problems. :dunno:
Where can you buy new brackets? Would love to replace mine.
Sweet. $15 kind of stings for something that should never wear out, but I don't know where I'm going to find a non-clicky one.
The door check assembly bolts to the inside of the door. My experience has been that the sheet metal of the door itself fails and the assembly is only attached by one bolt...if at all. It's quite easily accessible by taking off the door panel (which is pretty easy) and removing the speaker. Then you can reach right in there and start fixing it. If the sh metal is in good shape, you're good.
So then you just extend the check arm and put the pin in there...or am I not getting where your problem is?
