what are those splines from? i once had a splined shaft that wasn't hardened properly look a little like that. but the end near the shaft was also twisted about three degrees. the shaft didn't break but prop vibed and wobbled like you wouldn't believe.
were these stock shafts that were in a jy axle or did you order these custom and alloy?
if jy axles i'd pitch em and get something stronger. if alloy i'd hve a long talk with whoever made them. IIRC you have a doubler and are capable of putting an enormous amount of torque on those shafts. i suspect stockers won't cut it.
i remember yours mostly because that is where i heard of the box4rocks kit. after spending an enormous amount of hours doing mine from scratch i felt exceptionally stupid seeing a kit that reasonably priced.
definitely go for the beef. from someplace that will be there to talk to later.
