CanMan
- Lake Tapps, WA
Wil Badger said:Ya well switch to a real tire and I'm sure your lucky streak will end.I hate Ground Slicks they only work in reverse.
I dont believe they work at all.
MudAddict said:37's are too small... You've gotta go to at least 38's: :guitar:
(38 x 15.50 r16.5 Ground Hawgs on 16.5 x 9.75 Monster Rims - 5 on 5.5 pattern)
... and for all the web-wheelers & hard-core Pirate boys, this sucker's sit'n on stock D30/35 axles w/ ONLY a 3" susp lift and 2" spidertrax wheel adapters!!! Yeah, no chromoly's, D44's, full-widths, or other fancy stuff needed! Of course this isn't a rockcrawler either, but for riding muddy trails & sandy creeks... small lift & GREAT flotation + moderate acceleration = NO breakage!
I know in the Online 4x4 World... this truck's Taboo! Aint no way it could possibly hold up? Well, it does. I don't want to jinx it, but been using it as a hunting truck for a while & has yet to break anything! I mostly built it this way as a joke... was gonna run the stock axles til they snapped then swap to 3/4 gear, but jokes on me I guess, stubborn old goats won't die!
I'm sure some folks will say this is B.S., but its not... just thought I'd show what's possible for anybody out there on a budget that can't afford fancy beef. Just take it easy on the skinny pedal & the stock gear will hold up.
arty:
builder said:5"-6" lift on 35's will take you anywhere that 8" lift and 37's will.. without all the headaches, associated with taller lifts..taller is not better!
MudAddict said:... and for all the web-wheelers & hard-core Pirate boys, this sucker's sit'n on stock D30/35 axles w/ ONLY a 3" susp lift and 2" spidertrax wheel adapters!!! Yeah, no chromoly's, D44's, full-widths, or other fancy stuff needed! Of course this isn't a rockcrawler either, but for riding muddy trails & sandy creeks... small lift & GREAT flotation + moderate acceleration = NO breakage!
MudAddict said:Well, not everyone lives near & wheels in rocky or mountainous areas... there's a lot of flat land & farm country low land. Almost every 4x4 site has hardcore people that recommend lockers, axle upgrades, gears, etc. But a lot of times, this is overkill. I purposely built the truck this way to see if the hype was true and the axles would snap, etc... but they didn't. Yes, momentum is a big factor in mud & sand... but this aint rockcrawling! Lockers & traction will dig you down & leave you high-centered on the axles around here! Flotation is King in swamp / marsh /sand areas... so for the lower South Eastern U.S. of GA, AL, FL, MS, LA... this is an adequate set up.
Before anyone gets their panties in a wad & starts flame'n... I just wanted to reiterate that this truck was built for lowlands and moderatetly hilly trails... NOT rockcrawling. It doesn't see much flex so tires don't get sliced. For anybody out there that doesn't go to ORV parks or places with rockcrawling terrain... you can get away with bigger tires & less beef. For someone w/ limited $$ or a High School kid who must make every penny count on a budget wheeler, this is good advice to know... in contrary to the majority of build-up advice out there.
loke said:I agree with mudaddict's view. You don't really need to spend thousands of dollars to get your XJ to a level where you can have fun.
My believe is that you find out what you want to do with your vehicle and then start building from there. Take advice from others but also use your brain and common sense.
My little XJ is doing pretty well compared to vehicles a lot taller and with a much higher amount of $ spent. I am sitting at 3" with 31's and my only real problem is my carburator, not lift or tire size.
I wouldn't go bigger than 35's on an XJ though if you ever get on rocks. You can upgrade your axles all you want to handle the bigger tires, but you will also have to build a sub frame to keep the unibody from twisting apart with rockwells, 39's and gears in the very deep ranges.
Find out what you want your XJ to do and build it for it.
XJSpencer said:I'm surprised that nobody pointed out that a Dana 44 rear is undersized for 37's. I think we already mentioned that a Rubi 44 isn't much stronger that an HP30 if at all.
To get this back on topic....
What kind of knuckle and ball joint failures have y'all seen with the Dana 30 outer knuckles? I've got a Currie 9" front in the garage that has 30 outer knuckles. I've thought of trying 37's sometime.
uncc civilengineer said:I disagree... I've not broken yet (knock on wood)... Truss/chromo, etc. I dont see a problem.. I guess I have a totally different mentality compared to most others that wheel "bigger" tires in rocks...
vetteboy said:FWIW, on 33's I twisted the splines a little bit on my stock 44 rear shafts. 37's will require about 12% more torque through the axle shaft for the same propelling force so that would probably have been miserable for me.
Dana 30 failures - I primarily broke Spicer 760 joints, which unless I caught it immediately would usually destroy the ears on the shafts too. On two occasions the joint breaking took out the upper ball joint at the same time. I never broke a ring/pinion, or either shaft (stock). This was locked on 33's.
Only during one u-joint break was I actually "getting it". The rest of the times - probably 5 or 6 - I was "driving like a girl". Which put another way means that I wasn't revving it up huge or spinning tires all over the place - I was just trying to maintain a line or crawl through an undercut.
I don't like having to worry about stuff breaking. I don't like thinking "oo, can't go above 2500 RPM here or it might break", or "I can only turn uphill a little bit here or else I'll probably snap a D30 u-joint". I'd rather just wheel and trust my equipment to do what I'm looking for.
arty:
