RCP Phx
- Phoenix,Az
You know what that might make sense on an XJ with a low pinion D30 front. Anyone else agree?
If the donor for the shaft had the raised emblem, it would be a 00-01 with a low pinion d30. Stands to reason that since the yoke is lower it will be farther from the tcase and the shaft would be longer. Get a different shaft I guess or get that one shortened. Or take the opportunity to move the axle back an inch or so.
The front driveshafts are the same for both the HP D30 & LP D30.
What you haven't stated is what T-case you are running?
