JeepinAaron
- NC
I'm having some problems with a Detroit EZ-Locker. First off this is in my '99 TJ and not my XJ. I'm not on a TJ forum and figure this problem would apply to XJ's just the same.
The specs are a 99 TJ with a 2.5L and a D35 running 33" MT/R's. I installed the locker, per directions, it was very easy. I purchased a locker for the front D30 but havent installed that yet because of the problems in the rear.
After installing the locker, I made sure it was functioning properly. holding one tire and spinning the other results in racheting of the locker. Low speed driving is fine, turning in the parking lot resulted in no tire churping and the locker had a faint ratchet noise. HOWEVER, driving at highway speeds resulted in the locker engaging and disengaging, which created jerking and popping, even while driving straight. This happens from 20-40mph and I havent had a chance to get faster than that. When the locker is engaging/disengaging during driving it jerks me to whatever side is engaging/disengaging.
I checked my air pressure, I'm running 35psi all around. I rotated my tires to ensure that I didnt have a bent wheel that might be causing it. I dont think my axle shafts are bent, but they could be. I tore the diff apart again, took out the locker, inspected it...since it is popping at highway speed there is already some wear. I checked the springs, they were installed correctly.
Any ideas? It could be the locker, but the dern thing is so simple I dont see how it could be messed up. I am thinking bent axle housing. How could i check for this??
-Aaron
(yea the same aaron with an XJ that has no oil pressure, its been a fun week)
-Aaron
