98cherokeedriver
- HI
I know another death wobble thead, I searched too, a lot. So my 98 with 2" lift on 247/70R16 tires with WJ brake/knuckle swap has developed DW. The DW just developed after I changed out my cheep poly/JJ adjustable style LCA that were shot with Savvy offroad aluminum LCA w/ JJ at both ends. I set the length to 16" eye-to-eye and checked the alignment myself. Here is what is new within the last year: wheels, tires, LCAs, UCA bushings, TB, TB bracket (RE), TB joints (poly/JJ), lower ball joints, wheel bearings. I have inspected everything for play and tightness. Everything is tight, TREs, bolts, etc. The steering box has a slight amount of play in it, say 10-15* at the steering wheel, 1-2", if that. The steering has never felt better. I don't think the tires are out of balance as it doesn't vibrate at highways speeds.
I'm stumped.
I'm stumped.
