SeanP said:I would be very wary of using this method. Unless you run a jig rod and pucks through the carrier bearings and through the ends, you will NOT get the ends aligned perfectly. You will likely end up with a nastly wobble that will kill your hub and carrier bearings. I did a lot of research on this before I did the 14B ends on my 9" and I did it right with the help of a local guy (CJ66Dean on PBB).
SeanP
Does this imply then that the tubes are not aligned to begin with?
I wouldn't think you would get a wobble unles the shaft itself is bent. I could see getting premature carrier and wheel bearing failure if the housing ends are misaligned but not an actual wheel wobble.
For the jig you're talking about, would that just be a turned shaft to run through the carrier bearings and wheel bearings? I like the idea and it's pretty simple too.
I would still do the turned internal tube sleeve for additional strength at the joint, rather than just a butt weld.
