Digger87xj
- Buffalo Creek/Lakewood CO
Shims, dams, slingers; Just different names. If they move the pinion head, it all adds up to a total pinion shim depth.
What was the total of the original shims with the stock gear set? The new set should not be very far (usually no more than .003-.005") from the old.
What I'm reading is the pinion is way too close to the ring gear. If you are at .080" total with that last picture, I'd like to see a pattern test with .065".
Try to be consistent with the backlash when setting pinion depth. Moving .005" shim will change the backlash about .0025".
