bobnoxious
- Marion, MA
You didn't tell us you were installing a used gear set...
From the Yukon install booklet (and I've found it to be true myself...it makes sense). Torque input flexes and distorts the pattern after running it, so you need to look at the side that didn't apply a "torque distorted" pattern.
USED GEAR SETS:
When setting up a used ring and pinion, concentrate only on the pattern created on the coast side of the ring gear teeth. Pay little attention to the driver's side. This is true for most used gear sets, although both the coast and drive sides should be considered in some instances.
