chadc
- lychburg,va
I have a d30 from a 95, I replaced the c's with d44. When I ran it I used GM stuff, i think you could run ford knuckles to keep the 5 41/2 lug pattern. The axle has no knuckles. It had 4.56 gears in it they are no good. The carrier is probably still good. I needed to have custom innershafts made (ctm). It is an easy way to get hubs and servicable wheel bearings. 100$ as it sits. if anyone's interested let me know. I can probably set someone up with gm knukles
Chadc
Chadc
