ok..... let me think back.....
ok, so I started with stock (untrimmed) fenders and while running 31's I'd rub a bit here and there when compressing.... so I trimmed a little here and a little there upfront. The end result was that while on a trail I compressed on the passenger side and turn and pulled the fender in GRRRRRR So I got home and I trimmed the hell out of that fender so that it wouldn't rub. The plan was to still reuse the stock flares just redo the bracket, but I overdid it a bit... so here come TJ flares to the rescue with help of Ed Stevens
One fine Sunny day I stop by Ed's house where with his help the fenders get trimmed. The most important step is to plan things out first:
1. Take the stock flares off
2. Take the bumper ends off
3. Take the TJ flare (if that's what you're planning to use) and hold it against the fender. Better yet, put it up and have someone hold it for you while you step back to examine the look.
Then after marking it with a pencil or something (try to stay away from sharpies...) plan the trimming. The best thing for you to do is to trim a little bit less and then bend it up. THe bend isn't simple. Ed had a really good set of pliers (something for body work which had a wide flat set of jaws specifiaclly for metal bending) and bend up. You might have to make incisions in certain spots for the bend to make it, but try to do that as little as you can (you want the longest pieces possilbe so that they reinforce the fender).
After that you hold the flare against the fender and adjust (snip here, snip tehre, bend here and there). Oh... when I was doing that, I had to remove my drivers side washer bottle (it sits in the fender) so that I had room to work with it.... I will move it into the engine compartment... eventually LOL.
Anyways, after all was said and done I redid the inside fender lining so that I wouldn't get as much crap thrown towards the door, and I took a BFH to that lip inside the front fender and after couple passes I had it tucked against the body like it didn't even exist......
Now to finish things off, I masked off the fender in the shape of the flare (just a bit more) and I used the herculiner in spray can to finish things off. Then I took the tape off (don't wait tooo long for that... pretty much take the tape off as soon as you finish spraying) and I let things dry and put the flares on.... that's all folks
Let me know if you have any questions
Kejtar
P.S. I trimmed the bumper endpieces so that they were in line with the flare
