gorman
- South Africa
I'm in the process of building a new front axle for my XJ using a locally produced Gearmax pumpkin with custom made axle tubes. The inner C's are those of the original D30 and it will get WJ knuckles. The Gearmax pumpkin is based on Dana axles as they are owned by Dana Spicer and it comes with a factory locker. It's slightly bigger and stronger than a D30, but I don't think is quite a D44 - somewhere inbetween.
The question I have is: the pumpkin of the diff I'm using is a low pinion one. As I'm in the process of setting up the correct pinion angle and caster settings for the diff - most references I can find refers to HP diffs. The reference I found for a setup similar to mine (6" lift) but with a HP diff is 10 degrees pinion angle. Is there anyone who has done a cut and turn excersize on a low pinion front axle (I'd assume people who might have done this did it to a LP D44) - if so, what pinion angle should typically be used with a LP and 6" lift? My existing propshaft angle on the OE LP D30 is 10 degrees, but the pinion angle is not correct - if I were to correct the pinion angle, the propshaft angle will be reduced, not? (my current lift is not 6" yet - more around 5-5.5")
