- Rainy side of Washington
You definitely could, hell you could probably take a passenger drop one, cut the center casting out, flip the tubes and knuckles side for side (obviously swap the knuckles so the steering's still in front of the diff), and install whatever center section you wanted. Bam, kingpin driver drop axle that takes 60 size ujoints.
edit: oh, make sure you dial your caster angle in with respect to pinion angle while you have it all apart, that way you'll retain stock return to center steering stability etc while not making any compromises on pinion angle and driveline vibration.
