I was wondering if lower control arm skids are a good idea for rock play. They only cost $25 + shipping and redcbr007 will weld them on for an honest price. should I get them?
Yes, they are a very good idea if you plan to play in the rocks. While the welder is out go ahead and weld the inside of the control arm mounts. They're only welded on the outside from the factory and sometimes can break off.
I wish I had done that to mine a while ago. My tabs are all twisted up and mangled. Probably going to weld some scrap metal across the tabs to box in the area.
Any square/rectangular scrap tubing (3/16 or better) with a 3" side works perfect as well. You just cut to length, and cut the tubing past the radius on each side. Spaces it away just enough for any control arm to work. Beings that it's such a small piece, probably find it in people's scrap bin and get it for nothing.
