I've been meaning to do a write up on my Champion install, but I ran into issues and got sidetracked with making the thing work. I'll really try to finish the write up though so others won't have so much trouble with this radiator.
Here are the problems:
1. The quick connector for the lower tranny cooler line come out too far and interferes with the wheel well area. I zipped off a relief for it with a dremel and that part was A-ok.
2. This one is the more frustrating of the two. As Cuda said, the upper fitting doesn't work for the stock tranny cooler lines. Stock (for mine at least) is a flare, but they give you another quick connector fitting for it. Obviously a flare on the radiator won't connect to a quick connect on the line going to the tranny. To make matters worse, the nut on the transmission side of the flared fitting uses standard threads rather than pipe threads that normal flared fittings use. The threads on the radiator are pipe threads as well, and they're welded in so there's no changing fittings or threads on the radiator. Soooo, the two won't connect. In order to connect the two using the flared fitting, you would have to cut the flare off of the transmission hard line, remove the stock nut, and replace it with a flared nut with pipe threads to match the radiator. What I did however, was use the quick connector fitting supplied with the radiator, and I hacked the flare off of the tranny hard line and connected the two with a rubber hose and zip ties. I'll eventually re-flare the end of the tranny hard line for a more secure connection and replace the zip ties with spring clamps but for now it's working just fine with no leaks (tranny lines aren't under much pressure).
Yes, I was very frustrated with having to "fab" a vehicle specific product. I should be used to it though, it seems like at least half of the "bolt in" products I've bought I've needed to do some fabrication on. But my disappointment at the fitting issues were quickly forgotten when I tested the thing out.
I did the electric fan conversion using two stock A/C fans at the same time as the new radiator. It was 100 degrees out the day I got it done, how convenient right? :firedevil: Long story short, I sat in a blacktop parking lot with my A/C on full blast and my temp needle never even flirted with 210, no joke. Since then, I've also driven it around town in 70-80 degree weather with my fans completely unplugged (just for shits and giggles) with my A/C on and never hit 210.
So yea, I'm very happy with mine. As far as performance goes, this thing kicks ass. And it's not painted, it's just aluminum "dust" or oxidation or something from the manufacturing process. I can vouch that the thing is very high quality, looks great sittin in the engine bay :thumbup:
