canadian-xj
- Vancouver BC
Seen this setup on phatjeeps.com
http://www.phatjeeps.com/conversions/grnd_chk_steer.htm
I like the design but not into using heim joints on the street.
I am looking for a similar design but with tre on the end instead of heims.
I tried out the tera flex kit but it is junk. Had to send it back do to
not fitting properly and no provision for steering stabilizer. Tera flex should
call it low steer. Ended up hitting the sway bar brackets and the lower tie rod hung below the diff cause the knuckle was reamed the wrong way. Also if the tie rod fit like it was suppose to it would hit the diff cap.
