mhead
- Encinitas, CA
I have a '92 XJ 4.0 I-6 Auto tranny. Just put in a new stroker from Titan engines. Starts and runs! But after enough time for the engine to warm, and heater fan blows hot air - about 5 to 10 minutes operation, my temperature gauge hasn't moved, still indicating below 100 deg F.
I've read other posts and it seems the sensor is the one at the back of the head and not the one in the thermostat housing. Correct?
Does anyone know the electrical resistance this gauge should have at cold and 210 deg F? I can measure.
I did put in with teflon tape and note other posts say this might be the problem.
No reason to suspect the gauge or the sensor. Both worked fine with the old motor not more than a couple of weeks ago just prior to the swap.
Thanks!
Mike
Thanks!
Mike
