61scout80
- Chandler, az (alma school/202)
I bought a disassembled 2.5 liter xj. everything from the flywheel back was missing. So i bought an AX5 locally not knowing there were 2 different slave cylinders.
The jeep is set up for external and the trans is set up for internal. is buying and installing this kit all i need to convert jeep to the internal slave cylinder set up?
http://www.4wd.com/productdetails.aspx?partID=7945
Also, the little stud that the slave cylinder retaining sheet metal bolt is supposed slip on is missing. would it be a bad idea to tap this, or use a self tapping screw to hold the slave cylinder in place?
