bcmaxx
- The West Kootenays,B.C. Canada
I currently have bds adjustable arms in my 89 xj on 6" with flex joints.I have had some problems with them,like the threads seizing, so now they are all fixed, and not by choice. I end up having to rebuild the frame side end of them every 8 or so months, they just start clunkin and I get the front axle rotating when braking and letting off. The bds joint uses urethane races and the preload is not adjustable, I think they wear out fast because of this. What do you Naxja experts recommend?
- Keep replacing the joints when they wear out? (8-10 months)
- Install a superior adjustable arm with better joints? (insert your tried and tested recommendation here)
- some sort of heavy duty upgrade?
