8Mud
- Central Germany
Most of the time you get one click and nothing, it's the brushes. They sometimes make poor contact and the starter needs a little spin to get the Bendix to work ( and solenoid to seat all the way). The wire to the brushes is pretty stiff and sometimes the brush springs aren't up to the job.
If you whack the side of the starter to try and get the brushes to seat, you have to do it judiciously so the internals don't fly apart, but hard enough to do some good. I've never damaged one hitting it with a hammer and have pounded on a bunch (for twenty years) because there was mud or oil under the brushes.
Less likely but possible is a coat of oil between the starter and the bell housing. The ground strap on the block. A sticky Bendix on the new starter (seems odd they are both doing the same thing).
On my 96 the dual connector at the solenoid was burnt and the solenoid wire wasn't making good contact, but as yours is clicking this is unlikely. The starter relay and the wire from the relay to the solenoid is kind of anemic for something with as high an amp draw as the solenoid. The wire is about 16 gage.
