- Pekin IN/Louisville KY area
I like that look the best of anything I've seen done with other stock flares. dn aperworkSterling90XJ said:Thinking of going with 4 rear TJ flares instead.
I've dragged mine off before on terrain. But I think tire rubbing is caused by a combination of rim backspacing, tire size, and amount of flex. I'm on 31x10.5 with 3.5" of lift and popped one off backing over an 8" curb. (Didn't know it till something started flopping around as I drove down the highway. Rather embarassing....lol.)BORA 18T said:When you run a smaller backspacing the tires stick out more which in turn cause the fender flares to pop off more when offroading?
BORA 18T said:So let me get this straight, When you run a smaller backspacing the tires stick out more which in turn cause the fender flares to pop off more when offroading? Reason I'm asking is because I'm looking for wheels but can't decide on 4 1/4 or 3 3/4. which will give less rubbing?
Sterling90XJ said:.
Yeah, the flares on my '00 come loose from the metal brackets too when wheeling. Stupid design. I liked the ones on my '90 better. I too couldn't see Rough 01's pics, and would like to. E-mail: [email protected]
Had the same problem with mine and here is the solution.coderedxj said:Does anyone else have trouble keeping their flares on? I have a 99 Cherokee Classic and I have now pulled off two of them since I bought it. The front passenger side flare popped half-way off on a trail last night, and I was wondering what I should do with them? I would like to take them off and get some aftermarket flares, but I don't want to spend the money. It alos looks stupid with them off, so what do I do? I also would like to know where to get a good price on some front sway bar quick discos for my XJ with 2 or 3 inches of lift.
tsgolo said:I remounted my flares with ss screws. Since I was changing the mounting system, I also cut out over 1" of sheet metal. I could'a cut out more but wanted to keep the plastic wheel well liner and didn't want to lose the welds in the sheet metal.
Here's a link to a write up..... :repair:
Link to stock flare remount dn
Yeah, and they work too! aperworkSterling90XJ said:Hmmm... kinda like your own version of pocket flares.
Badcop said:Gary - your not from Alaska, I know for a fact, what you think Arctic is better than AKX???? Go TJ flares you puss.....LOL When did you PCS to FE??? Now get down here to UT and lets go....
BTW, TJ flares still look really cool especially when you add the turn signal and wire it in, you can get em through jeepsareus.com for like 20$ a pair.
holeshot said:Anyone have pics of a Flare-Less Chaerokee. Would like to see what it looks like with no flares. Thanks
