Blaine B.
- Northwest Indiana
It has to be. According to the website you don't need a longer belt to work, which is great.
Mine is a '93, but has anybody got just the new ps bracket and made their existing ps pump work with that bracket? I have an AGR pump I want to keep, but modifying my existing ps bracket to the new manifold isn't that elegant of a solution imo.tigerShark said:will the '95 ps pump fit in that bracket from a 99+?
wolfpackjeeper said:I used my stock pump, did not even unplug the lines. 2 out of 3 of the mounting bolts bolted right up. I drilled the threaded mounting holes on the pump out so they were through holes, then I put a metric bolt all the way through to the manifold and used washers to get it spaced just right.
I also drilled a hole through the pulley so I could put a socket on the mounting bolts without having to pull the pulley every time.
i would assume considering its adjustable.Blaine B. said:EDIT - Does the same size bent work on the newer pumps and brackets?
got any better pics of how you adapted the bracket to work?Jes said:I ended up using studs and nuts since I used the pulley off my '93.
Pics in this thread...
http://www.naxja.org/forum/showthread.php?t=84418
