philthyphil
- Bay Area California
1997 4.0 aw4 4x4
Ok so the p1694 saga continues, tried another tcm after doing all the pre- trouble shooting and p1694 still comes up, and cant be cleared. Started looking at the NSS (which already been cleaned and re greased) cleaned the connectors, and plugged it back in and still got the code. Went a step further and removed it entirely and noticed a bulge in the loom that was taped up. This is where i need the help. The red wire from the connector is going no where it is just heat shrinked at its end. and all the other wires have been spliced. From what i see it looks like someone spliced the wrong junk yard NSS to the original connector.
My connector has seven wires and the NSS side only has 6 wires and one of the splices two colors don't match. This is wrong right? And could this cause P1694.. cause I really need to pass the SMOG test. Thanks
...found this chart but the color codes don't match mine, but the pin placement is the same... Pin 3 red with black tracer is going no where.
