oldmustangjunkie
- Wartburg, TN
I would like to do a 2.5" budget lift. All the spacers that I see are either 1.75" or .75." Can I stack a 1.75 and a .75 spacer and get 2.5" of lift safely?
I had the ZJ coils on another Jeep and I thought it made it a bit to rough of a ride, so I'd like to just do the spacer thing. Thanks for the info. I'm think of doing something like this: 3" spacer, RE full length AAL, and rear block if I need it to match the front. Am I on the right track here?
sounds fine except for the blocks.
The main leaf is supposed to be good for 2", but there doesn't seem to be a standard for the additional leaves, I'd guess because of all the variables of wear & tear on the springs you'll be using. There is not much difference in the amount of effort in installing a full length aal & doing a bastard pack, except in prepping the donor springs.I may grab some leaves from some XJ spring packs and put them in. Does anyone know which ones I should use to get 2.5-3" of lift? Also, how is making a bastard pack any different than putting a full length AAL in?
I am a HUGE fan of the V8 ZJ coils and a spacer. Works well for a little over 3" of lift. The ride is GREAT too with a bumper and winch on the front.
