GrimmJeeper
- Gardena, CA
If you're lucky, the reverse drill bit might "catch" it and spin it right out.
x2, that's usually the case for me. Also I like to use the square extractors vs the screw type. People usually break extractors for one of two reasons. A) the hole drilled was not deep enough for the extractor to properly grab, or B) the hole drilled was not large enough. You want to use an extractor that fits snug at least 1/3 to 1/2 of it's length into the hole you drilled, and you want to remove somewhere around 70% of the broken bolt when you drill the center out.
