Bumpstops?
now for fronts since i know what i am gonna do on the back.
i was looking at just extended poly ones that go in the stock hole.
is that a good idea or are the ones that just sit inside the coil the best choice?
besides air bumps of course
Stacked pucks wasn't working out so well for me. The stock bumpstops suck when you hit them hard, and I bent the bumpstop towers on both sides.
I cut the towers off and swapped in 2" airbumps. Much better.
It's still not a high-speed desert rig by any stretch, but it goes pretty good. Trail riding and prerunning stuff is much more comfortable now.
For normal trail use, hockey pucks can be a fine solution.
For the levels of hell I put this thing through, it needed something a little more robust. :D
I run the Polly coil ones in front, went with the 10" ones. I run two sets one cut down to 3.5 rings(my race/jumping set) and one set cut to 2.5 rings(trail riding set). I had to drill a few 1/2" holes in both sets to soften them but they are the best thing I have ever done to my rig. Well worth every penny...andy miobi.org
