FatXJ
- South Range, MI
Let's talk about boost and spark plugs...
I am planning a supercharged stroker and am looking at some of the finer details.
First what I know:
When you add higher compression like a N/A 11:1 ratio or adding a Supercharger or turbo you need to lower the heat range on the plug to prevent pinging. You may also need to lower the gap on the plug to prevent spark blowout which occurs with higher cylinder pressures, especially at higher RPMs.
So with me planning a 4.7L motor running 7-9psi supercharger should I need to go to a colder plug. I am thinking yes but I have yet to build and run this project so I don't know?! I know theres a lot of what if's but let's just keep it simple for now.
Anybody running a similar setup have any info?
thoughts, opinions, general stupid comments?
First what I know:
