dellstopjeep
- KUNA, ID
have you ever been flat broke, but wanted to do something to your xj? That's me, what are some cool mods that don't cost any money?
dellstopjeep said:have you ever been flat broke, but wanted to do something to your xj? That's me, what are some cool mods that don't cost any money?
:laugh3:red91inWA said:insert your smart ass answers here ----}Use a BFH and enjoy yourself!____________________ I can hear them coming now...
mmmmmmm fiberglass.Beej said:Any paint or fiberglass?
lol. How did I know you were going to post that? Any other new fiberprojects in the works? Want to come up to BC and reapply gelcoat to my boat's transom?dothedew24_7 said:mmmmmmm fiberglass.
Looks good, but man, you need to clean your jeep!XJ_ranger said:
Originally posted by xj92
2. If you have a grinder with a cutoff wheel, cut the LCA bracket a little to give you more droop
xj92 said:1. Bend the hard lines of the front brake lines to give you more droop (zip tie them in place, or use an old shoe string if you don't have a zip tie).
2. If you have a grinder with a cutoff wheel, cut the LCA bracket a little to give you more droop.
3. Replace the nuts on top of the stock sway bar connectors with wing nuts to create quick disconnects.
4. Remove the rear sway bar to give you more flex from the leafs.
5. Make the doors removable by cutting off the lower hinge ears.
6. Weld the rear spider gears together to give you a Lincoln locker if you have or can borrow a welder.
That's all I can think of for now. It all depends on what tools you have available and what materials you have laying around.
What do you mean in your #2 suggestion...Got a pic to show what your describing for the LCA?
And the suggestion in #5 do you have a pic and or describe more about how to do it...
That looks like a damn good idea. I'm doing that tomorrow.rangerjoe2001 said:
