Hunter-LynchburgVa
- Lynchburg,Va/ Richmond,Va
Scott Mac. said:Does your diary still respect you in the morning.
i bet it waites for him to go to sleep then leaves
Hunter
Matt, what's your initial impression on these joints and have you had a run on them yet?
Fore Wheeler said:what's the advantage of Warn vs. Yukon?
I have the Yukon and was told that they're just as good as the Warn (from a Yukon dealer of course), so why is everyone here using Warn if you can get 'just as good' cheaper? Not alot cheaper, but cheaper.
Fore 'prob spending good money on junk' Wheeler
FarmerMatt said:Pretty cool. All it is is a 760 joint & caps with CTM like sleeves pressed into the caps. The body & caps are heat treated than cryo treated. I've been running standard 760 joints for the last 2 years without fail until recently when I found one side with the needles crushed. IMO the shafts are much more important than the joints. The shafts are what cause joint failure many more times than the joint fails on it's own. The first run on the joints was this last weekend on da Hammers. So far I like my wannabe CTM's & I notice nothing different between them & standard joints just driving the trail.
Matt
Beezil said:dear diary.
I tried to order cool axles today so the naxja people would think I'm a badass. I talked to a nice man, and he said to measure my axles. warn supports only the ford 44's that have a stub of 9.72,a short side of 18.91 and a long side of 33.91. I measured my broken short side and it is 18.625. The nice man thought that was interesting, but not problem causing. But he wanted to know what my long side is cause that's the side that matters, but those broken axles are not at home. So I didn't ordewr the axles, and no one thinks I'm a badass. I guess I'll just have to talk out of my ass untl then.
