Boostwerks.com
- Colorado
No I didn't mention I was running the WJ knuckles. At the time I talked to him and ordered it, I wasn't planning on the knuckle swap. That kind of came into the equation after the fatc. My plan at the time was to do a Vanco brake upgrade, so I would be keeping the XJ knuckles. After I read more and more, it worked out to be less money out of pocket to do the Wj set up than the Vanco.
I laid the WJ knuckle on top of the XJ knuckle to see the differences the other night. I did notice that the WJ tie rod arms a little lower, but I didn't notice a difference in the lengths of them.
I plan to run the tire rod over the knuckle, so I think that eliminates the tie rod hitting the diff cover. Frank Z was running the WJ OTK set up and he switched from the bent WJ tie rod to a straight one. There was no mention of any diff cover interferance. He did mentioned the bent Wj tie rod was more of a pain to adjust the toe with. I'll guess I 'll have to wait and see.
I'll post up some pics soon. I am waiting on ball joints, so nothing is assembled right now.
You will have to move the sway bar brackets though.
