gorman
- South Africa
I'm in the process of ordering all the parts I'll be needing for my WJ knuckle swap. For now I'll settle on all WJ tie rod ends from Moog. Some people say one should go for Chevy tie rod end at the pitman arm as it will allow for more droop - I thought it easier to just get all the Moog stuff for a WJ and be done with it.
Wrt the balljoint onto which the knuckle mounts. Seeing that I'm redoing the whole front end, it would be senseless to not replace these with new ones also. Now the question: On Rockauto where I'm ordering the parts from they list normal Moog lower ball joints (MOOG Part # K3185) and adjustable ones (MOOG Part # K7429) which offer caster/camber adjustment range from -1-3/4 to +1-3/4 Deg. Pricewise they are about the same. I was leaning towards the adjustable ones just to have the ability to adjust caster/camber when necessary. However, with these the way I figure you will have to adjust something when fitting these, i.e. you don't have the option to just select a normal OE setting as the mounting point on the knuckle is off centre. So when the axle is straight and it is set for zero camber, then it will affect caster and vice versa. Can someone shed some light on the use of these ball joints?....or should I just get a normal, non adjustable one?
