Okay so i was driving up to a welding class this week and noticed at about 45 to 50 mph there is a really bad vibration that seems to be coming from the front end. I have rotated the tires and replaced both motor mounts and tranny mount today because all were shot and took it on the highway again and it still happens. Any help as to what this might be??
I recently engaged the front axle full time and got rid of the vacuum actuated 4x4 as advised on here, Could it have anything to do with that?
Its a 1988 XJ 4.0 Automatic with a 4.5 in lift and 33 inch muds. has an AA SYE and np231 tcase.
Im pretty sure it has nothing to do with the drive shafts because when at that speed i threw it into neutral and let off the gas and it did not go away so ive narrowed it down to either the tires or front axle. unless im forgetting something?
Any help would be greatly appreciated!!!
Sean.
I like how everybody immediately goes into death wobble repair mode. He says right in the thread title it's not DW for cripes sake.
Would you characterize the vibration as more of a rapid thump thump, like a tire, or a buzz? By buzz, I mean vibrate the change in the cupholder rhythmically, make the mirrors out of focus?
These are very different vibrations with very different causes. And as mentioned before, putting the transmission in neutral (or even the transfer case) doesn't magically disconnect the spinning driveshafts from the axles.
From what little info is here I'm thinking front driveshaft, but there's no need to remove it. A bad driveshaft vibration can usually be found with a good under-Jeep inspection. Park on flat ground with the trans in neutral, parking brake on and tires chocked. Check each driveshaft at each ujoint, slipjoint, and double cardan assembly (in the front, and also rear with an SYE). Push, pull, twist, and look for play.
I have it with two different sets of tires one set is 31" mud country with airsoft pellets, and the other are stock tires professionally balanced. No matter what tire you put where it's the exact same shimmy.
I so could have written your original question myself!
Your description of what your rig is doing is exactly what mine is doing.
I too have had DW and resolved it and this problem I am having is definitely not the same. It could be a tire that goes out of round I supposed. Perhaps I should put 32psi in my tires. I usually run them around 20-25 because they bulge otherwise and wear in the middle. The truck just isn't heavy enough for full pressure.
I have another condition on my rig though. If I am on a slight uphill, like 1% grade (parking lot type of situation), facing uphill, I put the auto tranny in reverse and start gradually rolling, then tap my brakes, I hear a noticable clunk. I release and re-apply the brakes and the clunk repeats itself. I have redone my brakes and everything is good, so it's not the actual brakes.
I can't do the brakes and look under the rig at the same time so I don't know for sure what's going on, but I suspect a control arm bushing has failed. I am replacing all four uppers tonight. The lowers are part of the new arms I installed with the lift three years ago so I am going to tinker with the uppers first presuming the lowers are statistically OK. (The uppers are original mfg'd 8/86)
Hope you find the cause of your wobble/shimmy/bad vibe soon!
Rob
