"On my old ramcharger, I could induce wheel hop by spinning the tires, but I could also, on the same surface, induce then stop wheel hop by power braking....cuz the torque/suspension/traction factors were constant. When I let off the brakes, the traction changed cuz the truck could move, so the wheel hop would come back if I didn't let off some. Dry conditions were the worst.
I can usually do the same thing with my cherokee. Power braking spins the tires, but spinning the tires without using the brakes usually gives me wheel hop."
Sure sounded like you were talking about feathering the brakes to me. And to clarify, the hop occurs whether I'm feathering the brakes or not, like when I'm trying to keep my speed up in sand or snow. So are you going to say its because I don't have a front locker that it occurs? People need a front locker to make radius arms work? Or maybe it's because my Jeep is green, or my CB antenna is creating a weight imbalance. Whatever it is, it couldn't be suspension geometry. If your point is that stiffer shocks and springs might help the problem, you've made it.
And you're right, I probably won't be happy until I have a different suspension, and I'm speaking here to let other people who might be looking at radius arms of their inherent downsides. You're being pretty insistent for someone who has never had radius arms and has no skin in this game. I acknowledge that there might be things that could be done to lessen the problem, but I would have preferred to know about these things before I bought the kit. "Long arm" kits are so prolific on the market I think it lulls people into a sense of perfection, when in fact radius arms are far from perfect.
Well, you got me........sorry, I was wrong.....I guess since in both of the vehicles I mentioned in the examples in bold print above, the brake pedal was TO THE FLOOR, that I guess I was indeed feathering the brakes. Sorry, my mistake. I was also talking about the rear axles on them.
And no, I am not saying you have to have a locker to make a radius arm setup work...I AM saying using the brakes to get you lsd to work is defeating your purpose by slowing done wheel speed, which increases traction to overcome your current spring rate which lets your wheel hop get worse.
And again, no, I have no vested interest in, nor do I run a radius arm setup. If you had read & comprehended my previous posts, you'd see I am leaning towards a 3 link now instead. I also plan on a rear coil spring conversion....got any complaints on those I should know about ?
Yes, they are prolific because for 99% of the people who buy them, they work well, and that is partly because most people don't push them to the point of their limitations. Biggest complaint I've seen to this point, is the joints/bushings wearing out & getting noisy.
I'm still not sure you have either, but you do have other problems that need to get addressed.
Using the brakes to get an lsd to engage also sets up a power cycle from one side to the other, which can give the same affect as wheel hop, with the same results. One tire gets traction and stops and the other side suddenly has full power, so it jumps, then when it contacts the ground again, it stops and full power goes to the other side...and so on.....and on video, it will look just like wheel hop, and can be hard to determine which it is. When one side has power, the lsd can't hold power there long enough to move the vehicle, so it violently cycles side to side trying to find the least traction. At least with a locker, it can't cycle side to side.
I could make my ramcharger do the same thing your jeep does, and it had leaf springs up front and a lsd too. I no longer run lsd's. I got stuck once in a steep ditch cuz the front axle was doing the same thing yours does. The pass side was hard in and had good traction for the most part, and the drivers side was in the air basically, barely touching the ground. When I got on it, the pass side tire dug in, and the lsd sent power to the drivers side til it hit the ground, then it bounced up and forced the pass side in, then the cycling started....till it stopped. The problem wasn't the springs as much as it was the lsd & springs combined (worn shocks probably didn't make it better either). I had to walk a mile home & get the wife & my other ramcharger to pull it out. The power cycling resulted in a busted stub shaft and hub, which is why I couldn't get out...no 4wd anymore.
Personally, I think if you got rid of the lsd and put in a locker, you'd be fine.
