Blaine B.
- Northwest Indiana
lowrange2 said:Seals that keep crud out of the axle tube?... that sounds like what I need. are you talkin about a factory outer seal or some aftermarket dealio.
Aftermarket
All XJ's are 36mm!RCP Phx said:You need the equivalant to this(VW axle nut tool,same size,even more torque)! I went to Harbor Freight and bought a 1-7/16" socket,cut it in half,and welded it to a piece of 3/4"x3" flat stock.Then while applying pressure w/ a breaker bar you hit it w/ a BFH,NO PROBLEM!
RCP Phx said:All XJ's are 36mm!
Timber said:Should you use anti-seize on the threads of something like this? That would certainly help me out since I don't have a torque wrench that goes high enough for 175 lbs.
lawsoncl said:You could get creative with the bathroom scale and a 2 or 3 foot cheater bar. Assuming 3' from the socket to your hands, with the wrench horizontal, stand on the bathroom scale and pull/push until you are 58 pounds lighter/heavier (the math is torque = distance x weight, so it's 175ft-lbs/3ft).
Yeah it's redneck, but what else you going to do when you have to torque that ballhitch nut to 350 ftlbs?
I've looked into that sort of method before, and I just didn't want to go through all that if I didn't absolutely have to. I also don't really consider that redneck--just using your head for more than a hatrack.lawsoncl said:You could get creative with the bathroom scale and a 2 or 3 foot cheater bar. Assuming 3' from the socket to your hands, with the wrench horizontal, stand on the bathroom scale and pull/push until you are 58 pounds lighter/heavier (the math is torque = distance x weight, so it's 175ft-lbs/3ft).
Mine cost about 5$ to make.As far as retorquing goes,Ive used this method for over 35 years.My weight is about 150,so a 2ft cheater bar means 300ft/lbs of torque.Simple math!RCP Phx said:You need the equivalant to this(VW axle nut tool,same size,even more torque)! I went to Harbor Freight and bought a 1-7/16" socket,cut it in half,and welded it to a piece of 3/4"x3" flat stock.Then while applying pressure w/ a breaker bar you hit it w/ a BFH,NO PROBLEM!
lowrange2 said:I assume the lower ball joint presses out from the top down?
lowrange2 said:Should I repack the carrier bearings before reinstalling?
5-90 said:Since it's easier to turn the screw when lubricated, you need less force to turn it and achieve the desired stretch ("preload") in the screw shaft. Therefore, you reduce the torque. Failure to do so can actually result in pulling the threads off of the shaft or out of the part, if you're not careful (and will certainly result in deformation and potential failure of the screw, at least...)
Anti-seize, by dint of being so slippery, require a reduction of installed torque by half.
duke000088 said:Does this also apply to spark plugs? I just did a tune-up for the first time myself and torqued the plugs to FSM specs (IIRC 28 ft./lb.?). I used anti-seize on the plug threads (of course). Should I have reduced the torque on those -or- since EVERYONE uses anti-seize on plugs the good ol' FSM authors at Chrysler took that into consideration?
Sinking feeling in stomach growing... growing... help - I'm a newb and I'm scared!
Duke000088
