Trail Blazer
- Moberly, Missouri
got the brakes fixed today, so now its time to work on the trans. i drained all the old fluid out (just put this transmission on, did not fill the torque with fluid, was told it would fill via the pump in the trans) and added new fluid (6 qts). i started it up, let it sit for 1 minute so as the TC could fill with fluid then shut it off and checked fluid levels. levels were fine. started it up again and proceeded to run it through the gears, then shut it off again and checked fluid-fine again.
Started it up again to run through gears again and i can take my foot off the brake while in ALL the gears and nothing happens..... did i miss something???
