I looked up the Redline MT-90 on Summit Racing's site and the is an additional information button with a write-up from Redline stating that the MTl and MT-90 are both GL-4 rated. Is this OK?
yes
Have you tried detaching the slave cylinder and compressing the piston fully to get rid of the bubbles? I did a conversion to an external slave cylinder on my '91 AX-15 a couple of months ago and that's how I did it. On the first try it still felt like it had air in the line. I don't think I compressed the slave enough. The second try yeilded a couple of small bubbles and I was good to go. The volume of the slave cylinder exceeds the volume contained in the line between the slave and master so you should be able to evacuate the air using this method.
Let me make sure I'm getting you on the bleed procedure: you're saying detach the quick disconnect fitting at the incoming line to the slave, compress the slave (not easy to do since I have the internal version) to get any air bubbles to come out the top where I detached it, and then reconnect? How do I assure that I don't get any air into the line going up to the master, then?
Yes. Neither has the sulfurs which are corrosive to brass synchros.
When I rebuilt my AX15, I initially filled it with cheap Napa house brand GL3 with the intent of running it for a few weeks to break everything in and then change over to the Redline. It shifted so bad, I thought I dorked up the rebuild and was almost ready to tear it apart again. It didn't get any better driving it for threee days either. Thankfully I decided to drain and refill with the Redline oil. I actually went with half MTL and half MTL90 as we do get well below 0*F in the winter. The difference was like night and day. It went from really hard to shift when cold to easy smooth shifting. A little stiff at first on the subzero morning, but it would shift at all before unless I let it warm up first.
Of course, I did make one mistake in the rebuild that bit me on the rump about 30k miles later. I assumed when the previous owner did the clutch, they also replaced the pilot bearing. Nope. When the pilot bearing seizes it tears up the tranny input shaft and input bearing. I now have an AW4 in there.
So yes, get a quality synthetic oil in there!
