sandfreestyle
- Charlotte, NC
Have a 94 xj with 4.0/AW4 and since I did 1-ton swap the torque converter doesn't seem to lock-up. Per every calculator I've used I should be doing about 2300 rpm at 65 with 37/5.13, but I'm doing about 2650-2700 rpm. It get's into 4th but the TC doesn't seem to lockup.
My mph gauge is accurate per GPS.
Already checked the brake switch under the dash, trans cable adjustment, and checked/cleaned the NSS. I'll check the TPS this weekend, but is there anything else besides the TPS and the solenoid I should be looking at?
Trans fluid is fresh and clean too. No brake dragging either.
