I changed my motor mounts then started experiencing odd shifting. 1st is normal, kinda falls on it's face in second (but has always been like that), when it shifts into 3rd, the rpm's don't drop like normal, they remain constant as you press the pedal, but then suddenly jump up (torque converter?), then 4th is normal.
Logic would suggest that I stretched a cable and changed something by jacking the engine around. I replaced the TPS. While trying to adjust the tranny throttle cable: When I press the button and push the cable conduit in, it just springs all the way out. Shouldn't it stay in until I go to WOT and ratchet out to the right position? It just springs all the way out and stays there. Is it toasted?
Thanks and any thoughts are appreciated.
Ron
Ron
