ParadiseXJ
- Paradise, CA 95969
Why did you pull the AW4 to begin with? Front seal leak?
I also wonder if your AW4 somehow got air in it and foamed up. Read some interesting stuff recently about easy foaming operating conditions, too little or too much fluid, too high and rpm, too hot....that makes the blow out the seals and dip stick.
I pulled the tranny because it stopped going. It was full of fluid, but it was acting like the torque converter was empty. Several people said "your tranny is shot". I refused to believe that since I had no other issues with it...it felt like the torque converter did in my XJ when I popped a line and it drained out all the fluid. So, I pulled it, took the TCC to a local shop, he played with it for a while, shook it, tested the inner spline play...told me it was shot.
When I put the TCC back in, I check for play (up, down, in, out, rotational) in the input and output and scored or chipped spline/gears on the shaft and TCC...nothing, everything appeared perfect. I did not use the actual Jeep trans line connectors, I used generic connectors, that seemed to fit but I had rather a bich of a time getting them back in. I used the proper O-ring, spacer, o-ring configuration...but the clip was different and I don't think it sealed/clicked in very well. So if any air got in there, that would be the likely entry point. I'm still not sure if the vent hose is kinked either. I replaced the hose and changed the routing, and once I put the tranny back in...I'm not dead sure it's NOT kinked.
