RichP
- Effort, Pa
1996cc said:I tried it on the way home on bare pavement. Under braking, if you keep a steady pressure on the pedal (i.e. don't move your foot), and slip the tranny into neutral - based on what you two are saying, I should feel the vehicle start to slow down faster i.e. the braking force should increase with the same amount of pressure on the pedal. I did not notice any difference what so ever. And putting it back in drive before I came to a stop didn't change anything either - it didn't lurch forward. So if you two (and others reading) want to row your shifter everytime you stop, go right ahead, but I won't be wasting the effort.
You can see the same effect in 4lo, in one of our YJ's with the chrysler 999, engine idleing and 4lo the drivetrain will over power the brakes at idle unless they are really well adjusted. With that said there is a difference at speed, the engine does do alot of braking once your foot is off the gas so you get a two fold braking effect, engine and brakes. At slower speeds the engine idle can detract from the brakes ability to stop the vehicle. This is more noticable in a stick than an auto on the engine braking side, less on an auto tranny.
As far as a traction device, in the rear it will drive both wheels when power is applied and force the jeep straight ahead no matter which way the wheels are turned, pull your foot off the pedal and it will snap in the direction you have the wheels turned, apply gas and it will go straight again, interesting effect. Front locker in snow is interesting, I did not drive it long enough to get comfortable with it but the guy who owns it seems to do OK and he plows driveways.
