sandyeggoxj
- Sure would be nice to have a home...
haha. Good point. My d30 housing has about 1/2" of deflecting on the short side... And that is supposed to be the strong side.
whats with all the comments on the welds? you guys act like it matters if the housing doesnt bend on a dana 30......
not like the rest of the damn thing isnt gonna fall apart if actually abused.
You didn't see me saying anything. I just wanted to stop dicking with the rubber bushings. I know the thing is a noodle. Like I said, 9/60 or 609 will be my next front axle.
That may work for CA but deff not for the NE weatherterrain..the holes are big enough, just stick a spray can in one of them and paint the whole thing.
you need to "stitch weld" on the tubesBringing up an old thread. Question for the OP. I have been eye balling a truss of some sort for my HP dana 30. I am very capable of welding and do all my own fab. I am aware of the warping that may occur on the tubes and cause deflection as well. Did you do section by section letting welds cool in between or did you just go for it?
TIA
assgas:stitch welding implies leaving gaps. its commonly done to thin sheet metal to prevent cracking
that's not what you want.
what you want is what he asked about, weld a section, let it cool. then continue.
eventually, you want everything welded.
assgas:
Why not just stitch? A stitch weld has less HAZ. A big long continuous weld, even if you let it completely cool between each small weld, will have a continuous HAZ. How is that a good thing? The artec truss connection to the tube is essentially a stitch because of the gaps. So no worries there.
