Last question here, I am swapping in the new locked 8.25 this weekend, Should I wait to seal up the diff until the tires are on and I do the turning of axles to test the locker ?
Helping my buddy do his tomorrow... since it is a bone stock 8.25 with factory drum brakes ( 1999) we don't have to slide the axles out for the c lips because it is not disc correct? Or does it slide a few inches as a whole unit ( axle, drum brake, wheel) Thats really the only part I am a bit cloudy on
ah I got ya... ya thanks for the incite, I will be hitting this tomorrow. The instructions are so darn obscure but I am sure once you are down there it makes a little more sense.
Glad some one else thought that too. You don't remove the carrier , once spiders out you build it in place. Start with ring side. Then thrush washer and Locker Axle axle gear. Then I believe you slip the shaft and clip back in place. Repeat on non ring side. Not much room at all . Get a friend with tiny hands !
This lunchbox locker can easily be installed by yourself without any "helper." When they say "if you can change brakes then you can install an Aussie" they aren't kidding. I did a thorough write up with lots of pics on page three of my build thread
