- Minneapolis, MN
Remember Walmart and Sam's club. You get the warranty included with the $9.76 mount and balance. I cut a sidewall on an MT/R outside of Telluride CO and the Sam's Club didn't even blink on the replacement.
Here are all the features Walmart offers for only $9.76 per tire:
Mounting and Installation
We'll mount the tire on your wheel and install it on your vehicle.
Install New Valve Stem
If a problem develops with your valve stem, we will fix it at no charge.
Lifetime Balancing and Rotation
We will rotate and balance your tires every 6,000 miles at no charge for the life of the tires.
Road Hazard Warranty
Flat repair for the life of the tire at no charge or tire replacement if it cannot be repaired.*
*If the problem can't be fixed, you will receive a brand-new replacement tire at no charge if the tire has less than 25% tread wear. If there is more than 25% wear, we will replace the tire and prorate the difference based on the amount of tread left.
