vetteboy
- morganville, nj
xj8_8 said:Vetteboy
How much pinion deflection do you thank you will have? Where are you going to mount the back of the upper? I put my upper on the right side, I noticed the other day that I've twisted the tube in the housing, so i'll add that to the never ending list.
Pinion deflection? You mean the change in pinion angle? I sized everything to make sure that it remained within spec of the u-joint at full droop, and went from there.
Temporary axle upper mount:
and frame side mount:
Tubes are welded to the diff, plus fully trussed now. I don't think it's going anywhere.
