northernlightsfive
- Chicago Burbs
I wanted to get some advice from you all. I have a 99 XJ with 160k on the odometer. I wanted to just do a 2 inch lift (trying to avoid the vibes, but might be open to going higher then 2inches) and have accumulated the following new parts (most free):
-Pair of OME leaf springs (supposed to give 2 inch lift)/U bolts
-Prothane bushing kit (leaf springs, shackle, control arm, tie rods, ect)
-Rough Country coils (supposed to give a 3 inch lift)
-OME 1 inch transfer case drop kit
Most of my driving is on the road, with an occasional offroad excursion. I am trying to keep this as simple and inexpensive as possible.
I have a few questions about this set up:
-Will I still need an extended brake line in the rear?
-Should I ditch the rough country coils and go for the ZJ coils and a spacer (so the front is level with the back)?
-Will the front be jacked up too high compared to the rear (didnt know if the coils settle after a bit)?
- Am I missing anything important?
Any feedback would be greatly appreciated. Thanks.
