MK96XJ
- Asheville NC
A few of my rubber control arm bushings are shot so I ordered a set of Energy Suspensions poly bushings. I received these yesterday and read the horrible directions that came with the set.
Has anybody replaced their control arm bushings with the poly type? Do you have any helpful hints on doing this? It appears that I will need to use the metal sleeves that the current rubber bushings are in. from the looks of thing the rubber and metal is molded as one piece. If this is true I assume this job will be a real PITA to separate.
Any advice and or pics would be appreciated.
Mike
Mike
