- Golden, CO
Did all the other problems go away?
it does have an electronic side to the servo under the hood.
Not sure if the PCM comes in to play, I'm sure something is sending a signal somewhere. In my experience with Cruise control is in replacing the servos assembly in the engine bay or the control on the steering wheel. Usually one or the other fails because of heat in the engine bay or abuse from the drive toggling switches .
Jeeps have been good to us no issues with the cruise control .
But you'll probably know where the problem is when you test it out.
PS apparently from what I've read the cocksprings come with and without cruise control.
I've no experience with the 95 up cruise controls, when it the basic hardware it usually a simple failing.
When I read up on the 95 I was surprised the clock spring played such a important part, makes sense when you think about it.
Other part I'd look at is the brake switch, if we assume the clocksprimg is good, and kind of give the Benefit of the doubt to the to the servo and switch in the column, the next big culprits are the brake switch sending a bad signal so the Cruise control never engages.
I kind of doubt it's the pcm cause everything else works. But..
Brake lights can work and the switch still be bad. Although it's probably not likely.
The xj 91-96(?) controls several things besides the lights, cruise control and the torque converter lock and unlocking. When they do go bad it can be a pain to trace all that back to the switch. (It's got something like 6 wires going to it)
I'm going to check if I have a FSM for the 95-96 XJ. I'd almost like to believe there's a in line fuse someplace since everything else is working
If that part number for the servo is correct I'd hit a junk yard or eBay, it the same for dozens of vehicles even our 06 commander.
Liberty, grand Cherokee, commander, wrangler, neon,
If the online interchange is worth anything
fuse F13 in the PDC controls the Servo, they say to check that then go on to trouble shooting servo.
check for codes using the key. also check section 8h in the manual i sent you it has the continuity checks for the brake light switch and speed control switch.
did you check vacuum on the servo? may have gotten bumped and cracked while it was being worked on.
