MGrobe
NAXJA Member #968
- Chicagoland-area, IL
This is going to be my first foray into heim joints. I have a few questions.
1) Is the joint supposed to be non-lubricated? I assume it should be left dry.
I am in the Chicago area and see a fair amount of road salt in the winter. Plus when I wheel water and mud is usally unavoidable.
2) Any other maintenance that should be performed regularly or after trail rides?
If cleaning of some sort is recommended, then please specify with what.
3) When using them in a shock application for the front axle, which way is best for mounting the orientation of the eyes? My bilstein shocks have them both upper and lower. I am worried about avoiding daily wear and tear, plus hyper-extending the joint during extreme flex. I have a blank sheet at the moment as far as mounting is concerned, so now is the time to setup the rod ends in my preferred configuration.
Feel free to move this to modified if the mods deem it more appropriate there.
